solid green indicator light on dash
(In Topic #91489)
hi all, been having some problems with my clocks, all is well now after i rewired it a bit but now when you use the indicators you just get a solid green light and no indicators! if you push the hazzard switch they work!! :dontknow:
have fitted new fues, still no joy! i seem to be missing a wire on the hazzard switch, its a spade type large not small, what wire should go here and where does it go? many thanks
hazards
I am having the same problem mate.
Look under my posts and you will see some of the solutions
Hazard switch looks most likley my springs popped out of it and its been faulty ever scince.
Next is the replacemant of the relay.
As for that wire, If you put the plug onto the back of the switch there are 2 connectors. 1 is tiny for the bulb and the other is for the thick wire.
I think the wire is yellow with a black stripe in it but dont hold me to it!
Hope this helps
Hope this helps
