Sketch to help : Ignition/Switched +12V for Stereo
(In Topic #122929)
Read the previous posts, ran in new wiring from fuse box, might help others.
IGN OFF = RADIO OFF
IGN POSN.1 = RADIO ON / MEMORY INTACT
IGN OFF = RADIO OFF
8V
16V
Sportline
Campaign
16V
Sportline
Campaign
There are bare spade connectors on back of fuse box. Just remove bottom screw and lift off the fusebox, there's enough slack in the wiring to see the backplane. I found the spade clips on the left were all +12V constant, and only a few on the right were switched/ignition +12V.
Use a Multiimeter to buzz out each spade clip to see which one is switched/ignition +12V; when ignition key turned to posn.1 i.e. dashboard red LED's on.
8V
16V
Sportline
Campaign
16V
Sportline
Campaign
BIG BIG thank you for posting that, been searching a while as mine seems to have lost the original stereo wiring.
1272 driver with a magic tree!!
