sidelight/driving light prob
(In Topic #82018)
hiya - got a bit of a strange one…
when I turn the sidelights on (halfway on the light switch) the driving lights come on instead. they stay on when the switch is in driving light position.
could this be a faulty light switch?
cheers,
Tris.
cheers,
Tris.
that's a good question - I'm pretty sure the sidelights come on too, but will double check!
ok, checked - the sidelights do come on as expected with the switch in 'sidelight' position. the driving lights come on as well tho
ah bugger!
will try a new switch before starting to destroy wiring…
got this sorted - it was due to having a separate headlight loom and later electrics.
in later cabs, the dipped beams turn on a little when using sidelights. when you have a separate relayed lighting loom it gets switched on fully by this!
fix is to disconnect the resistor (looks like a pack of polos).
all fine now
all fine now
