Series 1 clocks into Series 2 loom
(In Topic #143268)
Hi folks, I'm trying to complete a dash swap in my golf, from what I've read the wire locations in the S2 loom are different to that of the locations in the S1 clocks - I have confirmed this as when I plug them in I loose the spark from the coil. Has anyone got a list of where/how the wires should be in the plug so the S1 clocks work? Thanks in advance.
WWW.DUBSHIRE.COM
clock swap
hi there i am also trying to do this swap did you find out how to swap the plug for the clocks switchs etc any help greatly appreciated
jammie dodgers rule
I did, google was my friend - found a pin location list for S1 and S2 14 pin plugs and swapped the wires around in the plug. If I can find the pieces of paper I wrote them down on I will post it on here.
WWW.DUBSHIRE.COM
Thanks for the info yea have started a search for the same info found bits and pieces but no complete list yet so if you do find the bits of paper superb cheers for the reply
jammie dodgers rule
series 1 , 1 empty , 2 indicator warning bl/ro , 3 main beam warning bl/we , 4 rev counter ro/sw , 5 earth brown , 6 instrument lights gr/blu . 7 live switch black , 8 fuel gauge li/sw , 9 temp gauge bl/ge , 10 battery light , 11 oil press bl/sw , 12-14 empty
