Self destructing speedo !
(In Topic #139150)
I can't even see how to get at the speedo, is it a big job? Also does anyone know of someone that can repair it once it's removed?
Car = 93 Clipper cabrio, with 80k on the clock.
Thanks!!
Luke
you can adjust the milage while the speedo is out easily, look down the top and you can see the digits and the gears that drive them. use 2 thin screwdrivers to push the gear 1 way and the number the otherm, then click it round till the desired milage is on your new speedo.
taking it out the dash isnt hard either, need to remove the surround which involves pulling the switch trims then switches (carefully!) then the heater slider knobs and surround, plus stereo. then a few screws and the trim comes off, and clocks arte then accessible. the speedo cable can be a mare to remove, needs a squeeze on the clip wiggle and pull to remove
the mfa wiring all goes to a plug on the back of the clock, 2 plugs if its the later mfa cluster where the 1/2 mode switch is on the stalk not the front of the dash
Speedo
I've just posted a brand new unused, still in its box from VW speedo on eBay if this gets you out of a jam. It's a Motometer uniit - item number 320818947037 - the reserve is a tenner
Hope this helps
Michael
