rpm gauge in a mk1 golf 20v
(In Topic #137407)
thanks alot
Website Manager
On my Emerald setup I bought a small module that Emerald do that converts the ECU output to a signal the mk1 clocks expect.
I have heard of people using a diode arrangement on one of the coil drivers to simulate the tacho signal and feed that to the clocks.
Website Manager
If it is a circa 1983 one with blade fuses then there is two places you can pick up the rev counter signal going to the clocks.
Find the B connector on the back of the fuse box and pin 19, there should be a red/black wire going from there to the clocks or,
The D connector pin 15, again a red/black wire that would of come from the coil originally, connect the output of your Jabba convertor to here.
Sorry never played with an AGU module, I am sure RJ or benscab will pop up and tell which pin to use as the input to the Jabba module !
Website Manager
Website Manager
Website Manager
