Reversing Lights Problem MOT Tommorow :(
(In Topic #89692)
Just went out to check some basic things on my car before the dreaded MOT.
And discovered i have no reversing lights!!!!!!!!
any ideas:
Bulbs looked fine.
Fuse what number/Position is the fuse i need ?
So i will break out the multimeter tomoz
I havent fiddled with the rear lights.
any ideas:
Bulbs looked fine.
Loving any chrome or carbon bits...
You don't need reversing lights for the MOT so you're ok
Its quite likely to be a rusty connector somewhere in the engine bay, make sure the connections are good to the switch on top of the gearbox and follow the wires up to another connector which can get rusty.
cheers is there a fuse i need to check ?
cheers for the help.
I checked bulbs they were ok.
one connector on gearbox was off replaced that still not working
removed every fuse, then replaced and now it works
woo hoo..
