rev counter feul gauge and temp gauge not working
(In Topic #130008)
rev counter fuel gauge and temp gauge have just all stopped working to day on christmas day off all days thanks father christmas any one out there no wot this could be lrt me know thanks people
:dontknow:
:dontknow:
Rev counter, fuel, temp, indictor warning lights not working
Hi tempa, I had the same issue with all three and warning lights cutting out randomly then coming back! Haven't had a chance to have a good look but it could well be as simple as a dirty contact/loose connection behind the dials, next thing I'll be checking is the main earth connections to the chassis behind the fusebox as I know this has caused issues for me before with other components not functioning correctly. Hope this helps, I'll update if I find a definate problem! Cheers x
Try the long 14 pin ribbon connector on the back of the instrument cluster. I've had a lot of issues with that before.
06 Audi A3 (Wifes daily)
thanks for you repilies guys it actually started working the next day and hasnt stopped since so very happy again but will need to b looked at soon as this promblem maybe coming soon in the futre
Could be the voltage regulator thats on the back of the cluster as this controls all 3 of these.
'81 1.8T
BMW R1200GSA
Caddy 2k 1.8T
BMW R1200GSA
Caddy 2k 1.8T
Got a brand new unopened genuine VW Voltage regulator here - £6 posted
could be fuse for them is dirty or the black wire is loose at the plug. check brown/white wire to side of head as well
Hi mate had ther same issue with my mk 2 scirocco, changed the voltage reg on the back of the dash panal and all is good! hope you sort it
