Relay problem HELP ASAP
MOT failure on rear fog light noticed the relay was missing and nobody seems to do one what other one would fit off another car any ideas please
Gary
1983 GTI-Black
MY very first one AND LOVING IT!!!!!
Try Crazyquiff on here.
If he doesn't have any in stock he will be able to advise you on where to get one from…
www.golfmk1.co.uk
HTH
Rich
Tried GSF they don't have any and without the relay I can'y even get a order code off it.
Can anybody have a quick look at there series 2 fuse board and just comfirm that it is relay number 7 as I may have others missing as well infavt if anybody could take a quick pic of 1 actually on the car that would be super
Gary
1983 GTI-Black
have you got the ceramic fuse board or the blade, mines the ceremic one if its the same i'll have a look
1982 Non Sunroof Black 1600 GTI
2003 MKIV Golf PD150 GT TDI
Should be a relay no7 for front and rear fogs. But there is also a fuze at the top of the fuze board for the fogs, should have grey white wires going to it .
You may not have a relay with just one rear fog [correct for uk on drivers side ] just a fuzed link as i said on the top of the board .
Check that fuze it should be above relay 5 .
    :D
Mine is blade fuses
1983 GTI-Black
    :D
I'll have a look Thanx
1983 GTI-Black
Hi,
   as already said relay should be no 7.
    pic of my relays out of 1.8 carb, same layout I think.
    info on 1982 GTI relays I have is
         1 (free)
         2 Inlet manifold heating (Carb) / Fuel pump (Inj) / Glow plugs (Deisel)
         3 Seat belt warning system
         4 Gear change up display (Formel E, GTi)
         5 A/C
         6 Twin horn
         7 Fog lights
         8 X relay
         9 (free)
        10 Wash-wipe interval
        11 Rear windscreen wash/wipe
        12 Hazard warning lights
        13 Seat belt warning system
        14 Seat belt warning system
        15 Headlight dim-dip
        16 Cold start valve
        17 (free)
        18 Coolant temp gauge (Inj, Diesel)
1988 1.8 carb Golf Clipper
Loads of VW ones in the scrap yard. The relay has 4 blades, with my car any 4 bladed relay works the fogs.
I've got some relays that i rescued out of a MK2 that we got on station to practice cutting up. When you find out what number it is , let me know and if i've got one i'll send it to you.
89 MK1 GTI Cab ( Helios Blue ), 64 reg VW Transporter T30 highline, Audi A1 1.4 TFSI Sportline..
djheap22 said
judging by that pic i got a few missing
1983 GTI-Black
That would be ideal that mate
1983 GTI-Black
djheap22 said
Hi,
         1 (free)
         5 A/C
         6 Twin horn
         7 Fog lights
         8 X relay
         9 (free)
        16 Cold start valve
        17 (free)
Different to the GTI model eg relay 11 missing [rear wash wipe not on Cabriolet ]. No7 relay was never fitted . Fogs UK was one rear 21watt bulb fitted to the drivers side .
Same fuze box in say Passat with top of the range bits would have had front and rear fogs and had a relay . Parts bin again , thats why your fog  light switch has 2 positions .  GWtaylor your fuze panel should look like this .
yep exactly like that
1983 GTI-Black
I'd always wondered about that  :)
Rich
