relay numbers ?????
(In Topic #135075)
relay numbers ?????
Can any of you identify the following relays by the number on them.
/83 1800 gti mk 1/
relay 2.
relay .17. MAY BE INTMIT/WIPER .
relay .5.
relay .19.
relay .20.
relay .21. MAY ME HAZZARDS.
relay .43. MAY BE FUEL PUMP.
THANKS
/83 1800 gti mk 1/
relay 2.
relay .5.
relay .19.
relay .20.
THANKS
This info is in the FAQ, I think?
just checked fusebox faq for you, cannot see a 17, no2 2 defo fuel pump and i have just changed my 43 that defo temp guage .. anyway heres what they are ..
2 = fuel pump (MK1 & Early MK2/Rocco K-Jet, no rev limiter)
5 = shift light and MPG gauge
19 = front wiper intermittant
20 = rear wiper non-intermittant (when you push the stalk forward, it'll only wipe once, no intermittant!)
21 = hazard/indicator
43 = coolant level sensor control (pre-90 & digifiz dash)
HERES FUSEBOX FAQ FOR EVERYTHING YOU NEED TO KNOW
Matt
Matt
Pump relay
Thanks for relay info.
I HAVE AS SPARES A NO 2 AND A NO 62 BOTH ARE IDENTICAL ,THE PINS ARE IDENTICAL AS ARE THE DIAGRAMS ON EACH CASE,YET THE 62 IS LISTED AS A MK 2 ITEM,MIGHT BE AN EARLY MK 2.
