Rad header tank
(In Topic #89761)
Rad header tank
If there is no water in the Rad expansion tank where should it come up as a danger
1983 GTI-Black
MY very first one AND LOVING IT!!!!!
If it has a level sender (easily identified by there being a sensor, and wires, coming out the top of the bottle) (1983 onwards I thnk) then it will flash the coolant light in the dashboard. If you don't have a sender, you have to check it regularly……..
sender is there
Is there any way of telling if it's knackered
should it come on on the dash for a second when turninng ignition on
1983 GTI-Black
I'm guessing its a plain old switch, so simply connect a multimeter to it and see if it switches on and off as you fill up the bottle?
