power hood wiring loom
(In Topic #159201)
i am fitting a power hood to my cabby but need a bit of help with what goes were in the loom department
Its a genuine unchopped loom so everythings there that should be.
Theres the red power that goes to the battery
And the socket that goes to the switch
And a brown that goes to the earth crown
But the ones i am not sure about are the
Purple (cut at the end but a socket half way down) ?
Black (double socket male and female)?
Blue/grey (must be illumination but again double socket male and female)?
Red (thinner red wire with 4pin socket on it)?
Any help much appreciated
1989 helio\'s blue clipper
One wire per side.
piccy below isn't good but gives you an idea of the control unit etc.
Cheers for that mate
Yes i have the control box, the loom is complete I have pretty much what's in the bottom picture aside from the wires on the end of the plastic covers, which I assume is were the purple wire goes.
Just need the location of the red 4pin plug and the black now, I won't worry about the purple if that what they are for (unless they need to by plugged in for it to work).
Have you got a better image resolution of the wiring diagram and the fitting page, I can't seem to see them when there enlarged they go quite blurry, there better than I have. The only stuff I have about cabriolet hood convertion is in the Haynes restoration manual and although very good, not as detailed as your pages.
Cheers kurt
chortle said
Hi Chortle,
Your comments on this thread are very helpful but a larger version of these pages would be awesome if you could post them? Thanks very much… Manda!
Capri green clipper cabriolet, my first and only car, met her before my husband, my daily driver for 15 years - only just beginning to realise what a mission that is and what a superstar car she is!
I realise I'm picking up an old thread here but I am just getting to the point of working out the electrics on my Barn-find 93 Mk1 Convertible.
Is there anywhere I can access the various diagrams shown here?
Do I read this that all four of the relays on the LH rear wing are to do with the hood mechanism??
I have just found the purple wires to the press studs for the tonneau cover and worked out that they must be some kind of interlock. VW thought of everything!
One of my challenges is that - at some stage in its past - the hood motor (now missing) has obviously deposited its hydraulic fluid all over the boot. This has done the metal some good but seems to have dissolved a lot of the wiring (or at least its adhesive tape binding!)
My cylinders are shot and the hoses missing - so I am considering just using it as a manual hood. If I do that - can I just remove the relays and wiring???
Any help and/or suggestions gratefully received!
The wiring diagrams for the good are in the back of the Bentley.
Many Thanks - something for a sleepless night!
Peter
