Points conversion to Solid-State Electronics?
(In Topic #84818)
SO perhaps im wrong but having been sent the wrong points 3 times now (VW insist its a Bosch one but it isnt!)
im at my wits end. i know lumenition do a kit (or did do a kit) but i can tget in touch with them
Loz.
Please don't call me fella- its deeply insulting to one whom is no such thing!
Where did you go to get your points? I'm sure GSF or similar will be able to provide - Why did you have them "Sent"?
There is not much to points, you could probably mod them to fit if they are close enough?
My Build Thread
try this link for something similar to what i need www.hot-spark.com the points that have been ordered for me by VW, and my my local motor factors and a mechanic are like these:
which isnt what mine take
all ic an do is hope that my mate whos a decent mechanic on older cars can clean them up long enough for me to run it til can get hold of this conversion kit and pay an autosparky to fit it!
My Build Thread
http://www.classicheads.com/Electronic_Ignition.html
I know it's aimed more at the classic and vintage market, but there's no reason why it shouldn't work on a mk1, it does say down the bottom they can custom make a kit for your distributer.
Mike.
1983 White cabriolet GTi
Whats all this about re-timing your engine?!!? eep! i can't do that!
Once fitted its pretty maintenence free……
Lozmk1 said
Whats all this about re-timing your engine?!!? eep! i can't do that!![]()
Unfortunitely you'll have to get the timing re-set if you get it converted to electronic ignition. Luckily a good garage shouldn't charge much to do it, as the ignition system on a mk1 is about as bog standard as you get, and therefore easy to adjust. Strictly speaking you should get it checked when you change the points anyway.
Mike.
Take a PIC…
I have optronic on a MK1 with a 1985 MK2 1.3 Lump.
demon tweeks supplied the chopper kit no probs..
If the timing is right as it is then it should not change when fitting electronics. It may help to have it tweaked but it should still run fine.
TT
however lumenition do 2 kits for the vacuum advance dizzy- clockwise and anticlockwise (from what i can ascertain from thier website anyway!)
HELP!!
