original v.a.g factory fitted alarm
(In Topic #81900)
hi all
i hope some one can help!!
i have had an auto electrician or should i say he thinks he is try and sort a problem i had on my dash but he never sorted the problem and managed to mess the alarm up.
When i bought my cab i was never given the key to the alarm and it was never activated. While the auto electrician was messing with it he managed to set the alarm off which has never gone off before. Now we have the problem of the car not starting because the imobiliser keeps kicking in and we have no key to reset it.
Does anyone have any advice on how to disconnet this v.a.g factory fitted alarm or even have any diagrams on the wires.
Any Help would be greatly excepted as i really need my car up and running.
PLEASE HELP!!!!!!!!!!!!!
In warrington.
Thanks for that info.
If i put the wires together under the cowling then can i disconnect the multi pin plug that goes to the alarm system will this stop the alarm/immobilisor working?
Emily
Thank you
Emily
Thank you
Find the alarm box and cut it out,the wiring from the box needs to be traced to where it goes and disconnect it all,if the wire in the origional loom is cut and redirected to the alarm simply join them back up and it will run ok,it will take a few hours but it will b ok :wink:
Bert
Bert
Thanks alot i will see how i get on. i will let you know thanks for the advice thought it was the end of the world when my cab wouldnt start. hopefully get it sorted
Emily
Emily
