oil buzzer help
(In Topic #130976)
oil buzzer help
There were no problems before I changed the sensor (I changed it because oil was leaking from it).
I have searched the site and it sounds like either the other sensor or clocks. I am guessing that as there were no problems before it isn't the clocks…
Is it likely to be a new problem with the high pressure sensor by the oil filter, something I might have disturbed or something that I haven't thought of??
Any help is much appreciated, I thought it would be a simple job today and i'd be able to take it out for it's first drive of the year!!!
Cheers, Steve
Guest user
I guess I need to replace the other sensor too but it seems odd that there were no problems until I changed the sensor!!
Help!!!
I think there is something wrong with the wire to the high pressure sensor or possibly the sensor itself. I have bought a new high pressure sensor but haven't had the chance to fit it yet.
To make matters worse I drove the Golf to buy the sensor and managed to lock myself out in the car park!!! But I managed to unlock it with a plastic ruler!!!
See if that works and if not then it's a process of elimination until you solve the buzzer problem.
DubPartz
i do have a set of spare clocks to hopefully resolve the problem.
B18DUB said
Another quick question… can I change the high pressure sensor without having to drain the oil?
Yes, but make sure you haven't just switched off the engine or you'll have a mini geyser ! :wink:
DubPartz
