odometer not working
(In Topic #82791)
Hi my odometer on my golf mk1 gti does not work. The rev counter and speedo work fine just the odometer. Any ideas why it would stop working? and if i need a new instrument panel are they easy to fit?
Check this out - tells you all about odometer problems, why they fail and how to fix them.
M
4130 Products - Step-By-Step
M
Here is an obscene amount of information on how to repair the odometer and trip meter. :y:
http://forums.vwvortex.com/zerothread?id=1065244&postid=27466325#27466325
The nice thing about this project is that once you get the cluster out of the dash, you can sit comfortably indoors to work on it.
Don't forget to carefully pull off the speedometer cable and the wiring connectors before pulling it out of the dash.
odometer
Thanks for the response in will check those links
