no rev counter, fuel gauge, indicator lights
(In Topic #77091)
Hope someone can help, my rev counter, fuel gauge, indicator lights on the clocks( green flashing ones) have all stopped working. I am hoping its just a fuse but on diagrams posted I can't find a fuse for these items. Please help and tell me its a simple fix. speedo works.
Look in the engine bay. On the rocker cover, at the rear on the gearbox side, you should see two brown wires on a tag, fixed to the corner stud. If not, they are probably hanging down near the gear selector linkage and need reconnecting. Good luck - Big
actually found the problem, it was a loose connecter on the bottom of my clocks, took all dash apart which was a bastard then put it together again and the things worked ok but now my indicators don't work. The green light comes on when the stalk is pushed up or down but does not flash anymore but no lights on outside of the car. The hazards work fine though so I am left scratching my head. why when you fix one problem do you always create another. just of to a field to scream.
Chairman
Check the fuse if you haven't, cause I had the same problem after I'd had my dash out the other week.
Dan
Dan
Saw that this weekend, while pulling my dash wiring out! It was a 10A fuse for the indicators - can't remember which one exactly, but it did just as you described. The green light comes on because of the hazard light switch feeding current back. Big
spot on cheers! no. 19 for future ref. off to buy 10a fuse now with smile on my face. thanks again . I love this forum.
