No lights in the instrument panel?
(In Topic #90855)
fuses are ok and the bulbs can be seen if you remove the panel itself.
83 MK1 GTI G60 85 MK2 GTI 20VT 2004 SEAT ALTEA 2.0 TDI SPORT
Web Team
Bassline66 said
How do I go about checking the bulbs? Are they hard to get to? Can someone possibly walk me through getting to the bulbs. Cheers
Fairly easy, take out the clocks, look on the back and you will see where there bulbs plug in. Two of them are located in the top two corners of the pod, the third, for the mfa, or whatever you have there is located at the centre of the bottom of the clocks. A 1/4 - 1/2 turn and they will pop out.
