No acc for the radio or the roof mrk 1 cab h reg
(In Topic #123952)
so here my problem i have no acc feed to my stereo i check all fuses they are all ok ,at the same time the roof has stop working , i have check the ign and it seems to be ok .
My thinking is that a relay some where in the car is not switching the acc circuit in,so that means no power to radio or power to the hood circuit.
can any one tell which relay should switch in the acc for the stereo and hood, a picture disuse would be nice .
I know this fault has been talk about before but know one has come up with a solution as yet , maybe we can put this fault to rest for the first time .
andrew
BE cool when tacking these babys
The radio SHOULD be wired to be on all the time, so there's only really 2 connections needed (power and earth), not 3 like some other cars. If its stopped working then check the obvious.
No idea about electric hoods myself, can't help there.
paul_c said
What do you mean acc feed?
This is the feed tat turns the stereo on when you turn the key to the first position in the barrel .
The connection socket has +12v straight from the battery which is used for the memory on radio, and the acc which is used to turn the stereo on and off by the key.
so for some reason i have no acc now
thanks for your reply
No, the Mk1 Golf radio isn't wired like this, the radio works no matter if the ignition is on or off. Indeed the Mk1 doesn't have an accessory position on the ignition switch, unlike more modern cars.
If someone's wired your stereo how you suggested, its non-standard.
Now you're saying your non standard stereo wiring doesn't work - sounds like its been bodged in the past, basically!!!
So you'll need to physically trace the wires and see where they've taken the "acc" from for their bodge, which now doesn't work properly.
Or do the later cabbys have an accessory position? :dontknow: :dontknow:
The radio i took out did have the same behavior , no key in ign no power to stereo , key to first contact backlight come on radio comes on .
racer said
late cabbys with electric hoods have the acc position on the key. as soon as you put the key in but not turned it makes a switch which powers the radio and the hood circuit. first find the wire which is from this switch and see if it works, but your right it most probably is a relay will try to have a look at mine and see which relay it is
Hey racer,
yes that is correct, thanks racer i will wait for your findinings
bless
andrew
no worries , this is why the forum is a good place , their is a lot of knowledge out their, and some people have had different experiences with different models.
i blame the companies ,always changing bits so the common man has to go to them just to change a fuse.
