New alternator required - what amperage?
(In Topic #107586)
The alternator is knackered even though it was a recon fitted 18 months ago but it sat around and didnt run much at all.
I`ve seen that there are two types, 65amp and 90 amp on GSF both for 1.8 8v carb engine.
I assume the 65 amp is the one but I am now not sure so any advice I`d be grateful.
Jon`s Dad
~Madferret
Mk1 1457cc 5door GX '83
65 amp it is then 8)
Sound system??????? I`m old enough to remember 45`s and it makes the turntable jump when I hit a bump 8O
Jon`s Dad
Life Member
And before anyone says it, yes I know the fuel gauge reading reduces as you use it… :roll:
OEM fitment is 45 Amp for the GTi
I am told its a 1.8 8v from a Driver but it has a Weber carb and 6 bolt 2 into 1 exhaust manifold?? :dontknow:
Jon`s Dad
Think of all the ancillory items you have, rear heater, main heater blower fan, rad fan, front fogs/driving lights.
45amps will probably be enough, 65 amp is better, and pick a battery to match.
~Madferret
