Mystery vacuum tube
(In Topic #82923)
![Michael in the usergroup ‘Local’ Michael in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Mystery vacuum tube
<img%20src="https://vwgolfmk1.org.uk/uploads/pbextract/686791/vacuumtube2.png"%20title=""%20alt=""%20/>
Trouble%20is,%20i%20don't%20understand%20the%20function%20of%20this%20fitting...%20any%20clues%20anyone?
Many%20thanks,
M
![](https://i116.photobucket.com/albums/o16/rigideast2/whatisthis61477.png)
![Avatar](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fwww.golfmk1.co.uk%2Fimages%2FExLink%2FAvatar.jpg)
![crazyquiff in the usergroup ‘Paid Member’ crazyquiff in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![crazyquiff in the usergroup ‘Paid Advertisers’ crazyquiff in the usergroup ‘Paid Advertisers’](https://vwgolfmk1.org.uk/themes/default/images_custom/PaidAdvertiserIcon.png)
![crazyquiff in the usergroup ‘Local hero’ crazyquiff in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![Ross in the usergroup ‘Old timer’ Ross in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Normally only cabriolets get that vacuum sensor. I can look up a bit more 'what it does' info when I get home if you like?
![](https://i2.photobucket.com/albums/y29/rossonline/sig1.jpg)
Yeas - mine is a GTi cabriolet - first registered March 1985
many thanks for your help.
M
Its in the Haynes manual wiring diagrams listed as 'Vacuum time switch' and its wired up to the 'switch for acceleration enrichment' which is located under the throttle body.
I'm guessing that there is enough vacuum in that pipe it actuates the time switch and that sends current up to the accelleration enrichment switch.
I know no more! Maybe its some full throttle enrichment thingy? Maybe it actually reduced the amount of air getting through the throttle body rather than increasing the amount of fuel?
Anyone know?
Cheers,
Ross
Thanks for your help matie - good job all 'round.
Readers of this post should be aware that the natural lay of this hose is across the rocker cover, causing the the hose to melt through. It is easy to replace - new hose available from VAG (357906092C) at ?2.84 and it is possble to relay it away from the rocker cover using a couple of cable ties: securing the hose to the braided fuel hoses running to the injectors.
M
