my wipers have given up!!!
(In Topic #75329)
my wipers stopped working completely last night,
the motor is still wurring away, but nothing is moving up front!!!
havent had a chance to have a look yet, due to being dark last night and having to work 2day (how inconsiderate!)
gunna have a look when i get home 2nite, so if anyone has had this happen before and would like to pass on any tips of what i should be looking for then that would be groovy.
cheers!
Jon
cheers!
Jon
1983 mk1 gti 2.0l 2e powered
newman cam
ported, polished, big valve 1.8 head
audi throttle body
SWWWWEEEEEETTTTTTTT
newman cam
audi throttle body
SWWWWEEEEEETTTTTTTT
are the spindles still turning? if yes, then the arms have come loose. if not then it's probably a linkage problem.
not entirely sure whats going on with them at the mo,
as i say the motor sounds as if its turning, but no movement of the blades, i cant hear any banging or clunking from the linkage flying about either!!!! i will have a proper look when i get home.
cheers for your quick replies though,
will keep you posted.
newman cam
audi throttle body
SWWWWEEEEEETTTTTTTT
newman cam
audi throttle body
SWWWWEEEEEETTTTTTTT
sorted, easy peasy!
the culprit was a loose 10mm nut sitting on top of the motor. so the linkage wasnt rotating at all!
just tightened her up and hey presto! i can see again.
newman cam
audi throttle body
SWWWWEEEEEETTTTTTTT
newman cam
audi throttle body
SWWWWEEEEEETTTTTTTT
