My MK1 clipper won't start..no spark!SOMEONE PLEASE HELP ME!
(In Topic #102984)
i changed the peirburg carb to weber, it started. Then when trying to adjust the timing, for some reason it won't start
ive changed the dizzy cap and rotor arm, the ignition module, plugs, and coil!
There is + and - current going to the coil and dizzy, but the HT hole in the coil isn't showing any current at all
When i turn the engine, its turning no problem, just not firing!
Ive taken out spark plug no1, and turned the engine, and theres no spark
Any help please, if someone could ring me on 0798-999-999-1, would be much appriciated and the beers and dohnuts are on me!
please help me someone, i need it running!
Roony
For an update, i changed the HT leads, spark plug 1 is now sparking….
but still isn't starting! is the timing badly out?
What is the best way to time the cambelt, heads, and dizzy?
Cheers in advance!
Roony
