My Headunit Keeps Blowing Up!
(In Topic #81626)
checked the wires - all correctly wired up e.t.c :dontknow: no idea!
Think i've blown the tiny red fuse that sits in the back of the headunit, can someone fill me in?
The red wire with fuse box is quite obviously 12V constant and the brown is earth, i connected em up and it blew the fuse.
My headunit is a Sony CDX-5000R 4x50W, i've had it running fine in a 79 and 83 polo. Havn't replaced the fuse with a new one yet, once i get one ill try wiring it up again. Also got a spare shity headunit that came disconnected, will try to connect that and see if it works.
Red wire - 12V Constant, Black Wire - Ground
there is a seperate wire thats been removed obviously by the previous owner, its a yellow wire with a black pastic box on, do i connect this to the 12V constant and run it as an extra wire off that? - making it the ignition or not?
