mk1 gti cuts out at 1200 rpm
(In Topic #79578)
ive got a bit of a problem with my mk1 gli cabby..it cut out on me as i was driving home..towed it back thought it was fuel pump so i changed that it wasnt lol..could start the car and it ran smoothly as slowly increased the throttle and as soon as it hits 1200 rpm it just goes dead no spluttering or backfiring..i left it for few weeks while i went on holiday…got back to work on it and it wont even start now
..pretty sure its electrical as i have tested the injectors and they are delivering the right amount of fuel but after that i havent a clue..any answers are appreciated
Fuel pump relay maybe ? You can remove the relay and bridge two terminals on the fuse board to check (sorry - you'd have to work out which were the main feed / output terminals). This will make the pump run all the time so you can see if it starts/runs.
Good luck with it,
Mark
Good luck with it,
Mark
Could be your coil.
Have you got a rev limiting rotor arm? Could be that…Spring could be broken or something?!?! :dontknow:
My Build Thread
My brother was having very similar problem, check out his thread here.
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=10029&highlight=
Hope it helps.
Hope it helps.
Mk1 Golf GTI 83 Y reg in Lhasa green
Rear disc conversion
Lowered 20mm
14" Campaign Pirrelli P Slots
Lowered 20mm
ha got it
found out what it was.....the alternator was knackered..!!!! just got one from the scrappy..that was knackered to tho..
