Mk1 golf gti 1983 indicators not working but hazzaerds are???
(In Topic #149912)
mk1 golf indicators not working
i have been searching the net for days now on and off i have found a few posts but nothing that helped me.
right my hazzrads work with and without the ignition on
the indicator stalk with ignition off makes the side lights come on to both the left & right when you make it
but when i put the ignition on i get no indicators?? i have checked voltage in to the stalks to be honist im just very confused lol
hope some one on here could help me or piont me in the right direction
thanks
tom
if its ceramic fusebox pin 8 for the ignition, 6 for live.
check wires too as said its black/blue goes to pin 15 on the hazard switch for ignition, live feed is red/white to pin 30.
be careful pulling the switch, they love to explode everywhere
i have a similar problem. iv got no indicators at all the hazards wasn't working but I changed the switch and they now work but I'm still not getting indicators. checked the fuse and it's fine the side lights left and right come on with no ignition so the stork is working.
Please help!!
check you have ignition live to the blue/black wire on the hazard switch pin 15 next
thanks again…
I have an '83 1.1 Formel E golf. Ceramic 15- fuse fusebox.
The hazards all work on the switch and with the ignition off, the indicator stalk lights up each indicator and leaves it on, not flashing, until switched off again. With the ignition switched on, the hazards still work fine but using the indicator switch causes each side to flash at double speed.
All bulbs working.
Tried a second (used) flasher relay.
Tested the black/blue wire at the hazard switch with the ignition on, test lamp lights up.
Tested fuses 6 and 8 with the test lamp and ignition on, replaced them just to be sure. Gave them a wiggle to make sure they were seated properly.
Am I looking at a new hazard switch? New column stalk?
All help appreciated. Thanks in advance
They can corrode really easily, and if not cleaned will cause a similar issue…..
But no harm doing it again to be thorough.
