mk1 golf 1800 gti '82 starts and dies
(In Topic #130859)
what could cause this?checked the coil and the tci-h on my mates car and they are fine. :dontknow:
06 Audi A3 (Wifes daily)
may well be, i have just put a new fuel tank, pump,accumulator, injectors, metering head and fuel lines in. so i do hope not.Jeevesraf said
Are you sure this fault isn't fuel related?
however i removed the module and the coil, tried them on my mate car and they were fine, have put them back on my car and it runs fine now, just need take it for a run as it may still break down under load.
defo not the relay, fuel pump seems to prime after its cut out. mine has never primed on ignition.bugfez said
fuel pump relay?, it primes when you turn the ignition on but does the pump continue running once the engine is started?
some do some don't.
Member 125 - 2005
