Miscellaneous wires
(In Topic #89918)
Miscellaneous wires
Leads to :
What is it for?!
Any ideas?! If you know what the plug is for then it might be possible to see what the piggy backed yellow wire is - I'm assumign it isn't stock!
Random wire from the loom - blue w/black stripe. Anyone know what for?
There's a brown wire with a female spade clip here, don't know what it should connect to
What does this multiplug go to?
the round plug is for your 0-1-2-3 fan speed
1983 GTI-Black
MY very first one AND LOVING IT!!!!!
Most of the dash ones only fit into the correct switch as it were which should help.
Back of the haynes manual has very good wiring diagrams and with a bit of patience you can work out (from the colour of the wires) where each wire should go.
Any partiular wire that you are having grave difficulty give me a shout back and I will make an extra special effort to have a look.
I don't know which bits of the dash are missing which makes it a bit harder!
I'll figure it out by Haynes/dvm if I need to but thought I might have some time saved by you lot
Thanks anyway
I think it might be one of the 2 wires onto the hazard light switch that isn't on the multiplug connector from the loom.
One has a small connector the other has a larger connector, like the small and large connectors you get connecting to the spade terminals on speakers.
Much appreciated
