MFA
(In Topic #72279)
MFA
My MFA works fine except for fuel comsumption, anyone had the same problem or can offer any advice?
Cheers,
Jon.
I forgot to reconnect mine and get very low MPG readings, but everything else works fine. If this is the problem then the econo-meter thing probably won't work either.
Cheers,
Chris
Cheers,
Jon.
Just posted one for sale:
http://portal.campaignregister.co.uk/modules.php?name=Forums&file=viewtopic&t=245&highlight=
Cheers,
Jon.
clocks in car now and its reading up2 16 mpg the needle thingy
goes to about 40 :?
1984 white s2 golf gti , 2017 Golf R
Cheers,
Chris
mines just started doing that reading about 10mpg low. Ive checked the pipe at both ends all looks fine. The econ gauge works fine. Any ideas or do you think it maybe the pipe still ?
GTI Campaign owned since 91 + GTI mk6
if you have the economy gauge(needle jobby),it means you will have the big type reverse light switch,which the needle gets power from.
these are v prone to going faulty.
you can split the switch and repair them using the little springs you get in a pen. 8)
if your needle gauge is working,you can adjust the gear change light (when it lights up), 8O 8) to become more of a shift light…
Riley is right - I split and repaired one once but didn't need the springs just a good clean of the contacts was enough to get it back to life
mfa probs.....
there is an inlet for a pipe at the back of the clocks but no pipe anywhere…..where should it be? where does it go?
help
