MAF blank on dash
(In Topic #85605)
MAF blank on dash
I have a 89 cabrio and all the dash works reasonably well except for the maf lcd screen which is blank any suggestions on how to fix and where to start?
Volkswagens With Attitude
If I had a pound for every post on this forum about malfunctioning MFAs….
If the MFA is completely blank but all the following work fine;
then the following will need checking;
To do this you'll need to get your dash out - which is covered in the Haynes manual - and then dismantle it - which isn't.
I would suspect;
All of this is not difficult to check, but you will need good, clean electrical screwdrivers, a light touch, and time to dis-assemble and re-assemble the dash.
You may find that having taken it apart and put it together again - apparently without having fixed/changed/adjusted anything - the MFA works perfectly, or at least partly.
This is entirely in keeping with the "character" of the car - enjoy your MFA while it's working
Just don't get too downhearted when it stops again - it's old, it's grouchy, it needs time to itself sometimes.
Ali Cabrio
PS - If none of the things in the first list work properly - then your problems may be more serious - as in loom issues, or dodgy wiring in the engine bay.
- Rev counter
- Oil pressure sensor (do you get an occasional buzz on start-up?)
- Dash lights
- Is the MFA getting power?
- Is the LCD screen correctly seated?
- are the circuit boards for the MFA intact?
I would suspect;
- The dash in your car does not match the electrical connectors - so the MFA is not getting power (can happen)
- The earth lead for the dash has become disconnected - so no power (I believe it's the brown wire to the cylinder head - check it is connected and well earthed)
- The LCD screen has shifted (unlikely but worth checking)
- The circuit boards have given up the ghost (can happen but… your car isn't that ancient - my 1985 golf MFA is still OK)
Ali Cabrio
Mars Red 1.8 GTi Cabrio 1985
Seat Covers
Scratches
Leaky roof
1 million smiles per hour
Seat Covers
Scratches
Leaky roof
