Lights on warning buzzer
(In Topic #86092)
The bits cost less than a tenner and it doesn't effect the parking light operation on the indicator stalk.
post if your interested and I'll get a diagram, instructions and parts list together.
Mk1 GTi White Cab '86
Mk4 TDi
Mk4 TDi
1off Changeover Relay (Maplin p/n N00AW ?1.98 )
1 off 12 V Buzzer (Maplin p/n FL40T ?1.21)
3 off Scotchlok Connectors
4 1/4" Red Insulated Blade Connectors
1m of 5A Wire (any colour)
Superglue
I glued the buzzer to the side of the relay. Then made the following connections.
To get to the wires you need to take the heater control fascia off and remove the whole astray assembly. Both of which you probably already know just pop off/out.
You then need to pop the heater fan control switch out of its holder. I gave it a wiggle and push from behind and it came out easy enough, removed the connector from the back off the switch and dropped it down to the ashtray opening to make it easier to work with.
Once all connections are made you can secure the relay/buzzer somewhere inside the dash, I have to say I just left mine hanging behind the ashtray, it doesn't rattle so couldn't be bothered to screw it to anything.
To test, switch on your ignition, you should hear or feel the relay click. Switch you lights on, nothing should happen at this time. Switch the ignition off and you should here a horrible buzzing sound to remind you to turn your lights off. Switch lights off, no more buzzing. This mod will let you leave your parking lights on with the indicator stalk without buzzing.
Obviously, please make sure you are reasonably confident with making wiring mods in your car and ideally you should disconnect the battery. I'm not responsible for any mistakes you make whilst working on your car.
Tian
