Lights not working!
(In Topic #81375)
Lights not working!
It's a 1600 diesel and has done 120K miles.
The electrics that run the engine things (sorry for being so technical!) work but the lights, front and rear don't!
It's had a tow-bar fitted at some stage, so I think that may have cuased the problem. All wires to that are cut now.
I've checked all the wires and fuses and cleaned and reseated them where I can. I've also replaced all the bulbs with new ones.
I have
1) all indicators and hazard lights work
2) one front sidelight works, the other doesn't
3) dipped headlightits - neither work
4) fulll beam - both work
5) rear sidelights - one work Ok, the other works but goes out when brake applied!
6) N/S brake light works, O/S doesn't
7) O/S reverse light work, N/S doesn't
I've swapped some fuses from my Mk2 to replace those that were missing from the fuse box
Can anyone suggest where I should start looking for faults? And where I will find an on-line fusebox and wiring diagram?
I'm hoping to get it sorted for Edition 38 at the weekend…..
Any suggestions gratefullly accepted.
TIA
Stella
1983 mars red 1800GTi on ATS cups
G60'd, schrick cam, chipped, 70mm pulley, pace charge cooler, rolling road 182bhp 250Nm of torque, 14.50 quarter mile.
