keeps going flat! grrrr
(In Topic #81851)
Is it just the battery? Charge it up, doesnt matter wether i drive around or not, its dead a few days later. Before i fork out on a new bat, anything else it could be, bad earth? The battery is about 5 years old.
Black MK1 GTI Campaign SOLD
Blue T5 GP 2010 Transporter (Van)
Orange M6L 2012 Brompton (Bike)
Neversummer 2012 Revolver (Snowboard)
Sounds like the battery's on its way out. Other possibility is the alternator, but in this case the battery should not drop its charge if the car is parked up unused for the week.
1983 1100 C
1983 1100 C
check with meter that altenator is charging the batt. then disconect batt for agood few hours check again then check voltage that will let you know if its a bad earth or a bad batt
<a><img></a><a href="Login to a private Photobucket.com album
cheers for the replys
Do you mean while its running, put a meter across the battery? or elsewhere?
If it isn't the alternator or dying battery, it could be your alarm/immobiliser if you've got one). I know my reasonably new battery goes flat in 4-5 days if I don't use the car.
Mk1 GTi White Cab '86
Mk4 TDi
Mk4 TDi
yes it should fluxuate on the rise or stay stable it should not drop a few volts
