instuments not working!
(In Topic #91332)
No.17 on my car is the one below
Check the earths are connected in engine bay and on gearbox,I believe there is also one under the car but dont know what it does
Fuse-swap for a known good one
Just in case,check the earth wire to the back right rocker cover bolt is still there
Timmyturtle said
Top row,second one from left is fuel pump.Big one with 2 large copper connector spades
Just in case,check the earth wire to the back right rocker cover bolt is still there![]()
cool, got tomorrow off work so going to try and track down the fault! grrrrrrrrr
im just after finding drawings for dash lights , the dimmer switch has melted . i think due to a short in one of the positive wires to the lights . tring to track them down is a bit of a mare . its a grey with blue stripe .
would you have a drawing for this too ? :wink:
mine is a 89 cabrio with a 16v conversion think its still the 8v clocks and loom tho .
As if you have shorted something a fuse SHOULD blow
