Instrument cluster and temp gauge
(In Topic #93933)
I have removed the instrument panel to see if I can fix the temperature gauge that hasn't worked for ages. Now that the car has aged… to perfection (1989, 19 year old) I believe that a working temp gauge is important.
Well, I have the panel in front of me at home and I have already identified the wire with an ohmmeter (it is the red/yellow one that goes from the temp sender in the engine block to lane n. 4 of the printed circuit).
Before taking the whole thing apart to isolate the temp gauge, what kind of testing can I do?
Simply sending 12 volts to the +ve lead of the temp gauge is enough?
TIA
Ben
TIA
Ben
Golf Cabrio 1.8 GTI Quartett, 1989, Helios Blue.
Land Rover Defender MY 2007, Carintia Blue
FIAT 600, 1954, grey
FIAT Panda 4x4 Climbing, 2009, Bianco Bianco
http://homepage.mac.com/bengi/PhotoAlbum36.html
You need a earth to the board , if bench testing you can use a 9 volt battery [type that go in smoke alarms etc] . Put earth terminal to Brown , connect + to red / yellow wire , guage if not faulty should rise slowly to 1/4 full .
If you need to do this on the car put a resistor in pos line to bring down the voltage or you may damage the board or guage .
chudd said
You need a earth to the board , if bench testing you can use a 9 volt battery [type the .
I have removed the gauge; it has three pins on the back:
this is the pict of the back of the instrument cluster:
What is A, B and C?
Many thanks,
Ben
