instrument back lights.
(In Topic #74661)
thanks
Early-1800 said
I had a similar problem when I got my Caddy. Turned out to be a bad connection where the ribbon cable plugs into the edge connector of the cluster. Waggling it about made them come on. If I can decipher my Haynes manual wiring diagram correctly its line 1 and is gr/bl which should be grey and blue. Check you are getting 12v with a multimeter when the switch is on.
You are correct!
Also if this doesn't solve I think can sometimes be the dimmer switch for the panel lighting
Hairyarse said
You are correct!
thanks both. it was a dodgy connection on the ribbon after. working fine now thanks.
