INDICATORS
(In Topic #74322)
INDICATORS
had a problem with my 88 cab for a while. changed my side repeaters for clear ones, and the indictaors stopped working. thought mybe id chaffed a cable or something, but all was fine. put the stock ones back and still on indictors. ive checked everywhere i can think of to find a short, my dash looks a right out state with everything exposed!! hazards work, but wen i use the indictors just get the green internal lite on constant. looking through the service history its been a problem in the past and been rectified. is this a common fault? and if so where should i be looking??
cheers all
I had a similar problem with mine but the hazards didn't work either.. replaced the switch and it's been fine since
If you've got a voltmeter see if your getting voltage from the fusebox
apart from that I can't think of elsething else.. sorry
