INDICATORS
(In Topic #74322)
INDICATORS
Hello all.
had a problem with my 88 cab for a while. changed my side repeaters for clear ones, and the indictaors stopped working. thought mybe id chaffed a cable or something, but all was fine. put the stock ones back and still on indictors. ive checked everywhere i can think of to find a short, my dash looks a right out state with everything exposed!! hazards work, but wen i use the indictors just get the green internal lite on constant. looking through the service history its been a problem in the past and been rectified. is this a common fault? and if so where should i be looking??
cheers all
cheers all
The indicator's run through the hazard switch, I'd start there by taking it apart and cleaning it all up (be careful though, there's 2 teeny tiny spring's in it) and make sure the wiring to the switch is in good order to!
I had a similar problem with mine but the hazards didn't work either.. replaced the switch and it's been fine since
ive already replaced the switch to no avail. been laid up 4 a while cos i got dishartened with it. think ill start with the switch again and work from there
:scratch: if the hazards work then the relay should be ok.. only other thing would be wiring :dontknow:
If you've got a voltmeter see if your getting voltage from the fusebox
apart from that I can't think of elsething else.. sorry
cheers mate. spent about 15hrs with the multimeter before the battery died and i got disheartened. put a new battery on at the weekend and ran her up but didnt get a chance to start looking again. hopefully the break will mean i can find the fault quickly this time
Hope you find the problem...Let us know how you get on
Also, check (and clean) the switch in the steering column...
