indicators- dont!
(In Topic #99305)
indicators- dont!
Hi my indicators arent working have done a forum search on indicators and tried most things before posting this so would be grateful for any ideas
The indicator light glows dimly all the time with ignition on, glows bright when indicating but doesnt flash and neither do the indicators
Hazards work fine so all bulbs ok and it would appear the relay,
swapped relay from the Mk2 one which appears to be the same-no difference so I think the relay is ok
one post suggested the hazard switch can be faulty which everything goes through so Ive swapped to a new one- no difference so that should be ok
have had the indicator switch off the steering column- connects ok tested witha voltmeter so switch seems to be working
running out of ideas- anyone got any? :dontknow:
inters soon and I need to get it fixed grr
Lewis
Lewis
:? I had this problem and it definitely was the hazard switch
if you try slowly moving the hazard switch from the off position, does the indicator light go off at all?
Other than another relay (is it seated correctly?) and hazard switch… bit of a long shot but maybe worth checking the connections to the back of the fusebox :dontknow:
Hi thanks Ive swapped the hazard switch guess I ll just have to check each connection in turn
feels like the indicator lever on the dash ight be it given the other bits work but the switching seems ok
cheers on the headlight tip, where exactly do you mean? the earth wire to e nearside light? or something else
cheak out the brown wires,give them a wiggle,it worked for me,if they did work and just packed up,it sounds as if the wire has gone rusty inside so then trace them back and replace,with out seeing the car i sound a bit vauge
checked the wrong fuse!
ops:
should have been no 19
Thought it was ok- new one seems to have solved it
DOH!! :roll:
thanks for help chaps
DOH!! :roll:
