Im going mad.... mk1 golf electrical problem
(In Topic #138862)
Hi all i have had a look around but i cant find an answer to my problem, you would make my day if you could shed some light on these problems.
my indicators dont work but the hazards do, i have checked all the fuses and tryed the trick with the hazard light switch, I have also changed the hazard switch and changed the indicator stalk assembley……
the oil light flashes when running
the temp light flashes when running
when the head lights are on the dipped beam shows full beam on the dash and visa versa
when i move the dash light level adjust the main beam light goes out and the oil light comes on.
i am going out of my mind with trying to work out what the problem is.
any help would be great
Thanks Mark
Thanks Mark
trust me i aint no mechanic but have you checked all relevent earths? :dontknow:
i have checked the earth bank behind the fuse box on the n/s is there another on the o/s???
i think there is one for the dash alone,again :dontknow:
Hi mate,
Bit of a long shot, try all the earth points even the one in the boot. I had mental time trying to sort out a wiring problem and discovered the loose wire earthing (or not) the number plate lights. I just ran a new earth to the rear lights and that sorted quite a few things out.
It is a pig of a job when there is no logical reason to the problem.
Good luck mate.
Steve
Good luck mate.
Steve
thanks very much for the replys people. I dont have the time to look at it till sunday so i am make a list of possible problems to check, i am going to run a new earth from the battery to the earth points first thing then its head scratching time.
dash earth runs to the side of the head, start there. look for any brown and brown/white ring terminals. check the gearbox earth is good and clean, also the later models have a braided earth from rocker cover to one of the coil mounting bolts this can help a dodgy dash
All sorted…..
The problem with the dash clocks is/was the plug that goes onto the dash clocks, with a little wiggle it was all sorted so must have been something not sitting correct, as for the indicators i tryed the hazard light switch half way and they worked so i guess the problem is the hazard light switch after all. I hope if people have this problem they can fix it.
Thanks guys and girls
