Ignition sw fine now, key/barrel broken ....
(In Topic #82794)
Right, well updating today as I made a bit more progress…basically found out the ignition switch tha the AA declaered knackerd is fine, and I have cleaned a few connections and things on the fusebox, and if I remove the ignition switch from the holder in the lock cylinder (correct name?)and if I connect it directly to the connector that goes in to the dash somewhere, and use a screwdriver in the switch it starts just fine…
But when I put it all back and turn the key it doesnt work..has it just worn down or something? don't want to really have to get a whole new key set….
any help appreicated..
Dom
Dom
Life Member
What do I slide off the column? where abouts is the switch and how do i change it? is the allen bolt directly underneath? what does removing the allen bolt thats through a bracket?
help ops:
help ops:
updated, any help appreicated loads….
