Idicator flashing when all power is off??
I noticed last night as I was walking away from my cab that the passenger side indicators were flashing. The ignition was switched off! I went back to the car and made sure that indicator stalk wasnt left in position - it wasnt.
As far as I can tell there was no obvious reason for the indicators to be flashing with no switches on and no igition turned on. It wasnt Hazard lights, just the passenger side only.
I had to leave them to just flash!
Any ideas?
hazard switch gets perment live feed so id say its probably down to a fault with that, or moisture in the fusebox. could be a relay fault also?  if it has an old alarm that is also worth checking
Sorted…Just had a play about and discovered it was the alarm thats fitted to it under the bonnet, causing the passenger side to flash but making no sound. Turned it off, job done!
As far as i know, it didnt work properly anyways.
Cheers mate  8)
