How do i remove my clocks dash console HELLLLP!!!!!!!!!!
(In Topic #126516)
i tryed changing the bulbs on my speedo and rev counter today and spend hours wrestling with my dash and then couldnt get the spedo and revcounter bulbs in and light up again so had to drive with a torch on my dashboard so i could see the speed lol does anyone know how to release the console to get to fit the lights easily ???#
any advice would be very much apreciated and pics would help
Website Manager
Remove the two switch covers.
Remove the 3 heater controls.
Remove the blower switch.
Remove the 4 screws holding the dash surround in place, two are vertical.
Remove the radio framework if you have one.
Remove the screw just inside the radio hole at the top.
Pop out each of the switches and remove the connectors on both sides of the dash.
Remove the dash surround.
Undo the two screws either side of the dash holding the clocks in.
Put your left hand around the back of the dash and release the speedo cable.
Pull the clocks forward and remove the connectors.
The clocks are then free for bulb replacement !!
cheers for that great help try again tommorow if the car in the pic is urs thats nice thats same reg year and colour as mine much tidyer by the looks of it tho lol
Be very carfeful when taking the power plug off the hazard switch especially as this one has a tendency to pop open and spill all it's contents. Best to gently lever a small screwdriver in between switch back and plug and slowly do it.
Disconnect battery too and when you put it all back together don't over tighten the dash surround screws as the RHS lower fixing point is fragile.
DubPartz
