horn problem
(In Topic #86345)
horn problem
but the only things that still are not working are the reverse light and the horn,
i have no power at the conector block to the horns, which could mean the fuse, is the reverse light on the same fuse?? because i have no power to the light either, if it is the fuse what number is it beacuse i cant read german and couldnt seem to be in the manual??
anyone help me please.
On some mk1's (mine and yours) both the reverse lights and horn are on the same fuse (number 9 fuse). Try this fuse, if no luck try tracing back the cable, checking for breakages!
Also, i was told to take off the centre cap on the wheel as the contact the the rear has a tendency to rust/rot away!
Good luck m8!
Jesus is my airbag!
'83 Mars Red GTI
Rolling project!!!
Rolling project!!!
There's probably a thread on this with circuit diagrams etc, - might be worht a search, but it's simple enough to do anyway
thanks alot
8)
1984 white s2 golf gti , 2017 Golf R
