Help with fog / main beam
(In Topic #111064)
In other words, is the vertical pattern on the lens thick, or thin? And what's the numbers and codes on the lens?
reply
1987 gti cabby
If they're driving lamps, they simply piggyback off the outer lamps' main beams. If they're fogs…..its from position 1 from the foglamp switch but I'm not sure if it has a relay or not in there (I've always had single lamp grilles, except Scirocco which is differently designed again).
either way fogs or spots they shouldnt come on with the sidelights, follow the wiring from them and see where they plug in!
