Help needed
(In Topic #93749)
Help needed
Hi again, I have sorted the fan belt,it was just a little loose. Now i have a another problem
I had to bump start it the other day because it has been sat for a while,but when i was driving it it started miss firing then just cut out!! now it wont start :cry: any info would be so good.
Cheerz again.
Gav
1983 GTI
Cheerz again.
Gav
1983 GTI
Cutting out is due to one of 3 things: ignition not working properly; too lean; too rich mixture. You can't tell which one this is by looking or listening to the engine, you need to do tests. Obvious 1st one would be to check for a spark. Then check static timing. Then you're into checking the fuel system.
