Help needed with flickering speedo / clock
(In Topic #130883)
I have a dodgy speedo on my Mk 1 1.8litre Clipper.
I have heard that it is a common fault and I read somewhere that it is related to the speedo cable or the 'drive gear' of the cable.
I have seen on ebay there are 2 types of 'drive gear'
A red 15 tooth drive gear, seen here:
red cog
And
A clear 16 tooth drive gear seen here.
clear cog
Does anyone know which drive gear I would need?
Would I also need a new speedo unit completely?
Any help very much appreciated.
its on the flat plate on the bottom of the bellhousing, 2 or 3 digit code followed by 6 numbers
I have a photo of what is potentially the code but im not sure that it is. Its a flat blue plate
There is a picture here: 2 pictures
Sorry I couldnt figure out how you put the photos directly on the forum.
I think this blue plate is on the brake servo though. Perhaps if you can tell me in relation to the photograph, where abouts this number is written. I am living abroad currently so I will be relating the info to someone else. From memory there was a number engraved into the metal work, would this be it?
can it be seen from looking in the engine bay, or it is on the underside of the car?
the box code is underneath the gearbox, i.e. you have to lie down and look
2nd pic, on the square yellow box:
020 Oil
I will ask someone to check it for me and let you know in due course
OK so I have checked and the code under the gearbox is
AUG28042.
Underneath the letter G there is a 7, so potentially the code is AUG 7 28042
Please could you help identify what I need to do next?
Would this mean that this is not the original gear box, ie. it has been replaced with one from the mk 2 gti,
or it just happens to be the same as the one in the mk 2 gti.
Ive seen the cogs/speedo gear thing for sale on ebay so i will buy the red one.
Is there only 1 type of speedo cable ( I have a bright white one) or do i need to buy a new one of these as well?
the cables are the same, just make sure the little circlip is there on the end otherwise you'll loose your nice new gear inside the box!
