Help mk1 g60 conversion no spark or fuel pump
(In Topic #146069)
the black wire to the coil shows 12v and the thick green wire forms the circuit to this however when you check the coil there are no sparks on turnover, I have replaced the coil. I have checked the voltage to all the earths and they form a 12v circuit when checked to their corresponding live. I have checked the power and earths to the g60 ecu and they are all showing the correct voltages.
When you turn the ignition, the battery light stays on any help would be hugely appreciated, or if anyone is the Watford area and knows about this I am happy to sort out a few beers for some help :-)
the black/yellow wire is ignition live, factory yes it goes to ecu switched live wire
the g60 ecu has the tci unit built inside it this might have gone i suppose
I am almost tempted to take the whole loom apart again :-(. I hate electrics lol
