Help, identifying these wire for conversion.
(In Topic #146253)
Hi folks,
Just getting ready to put my engine(20v) in my bay (1.6 carbed petrol). I have just about traced all wires and connectors in the bay, apart from these ones listed below. Also what do you folks do with the ones not needed?
Fan brown + black/ red needed
rad sensor red + black/red needed
intake pre-heat switch black+ lilac/red not needed
horn brown+ black/yellow needed
low pressure oil single blue/black ?
high pressure oil single yellow needed
coolant temp sensor brown+ yellow/red needed
coolant level red/blue+ brown needed
reverse black+ blue/black needed
manifold preheat white+ red single 4mm csa ?
? black+ lilac/white ?
choke thermo switch black+ black/ yellow not needed
over run valve brown+ black/yellow not needed
element pre heat black+ black/yellow not needed
brake fluid brown+ blue/ brown needed
The Questions marks refers to either not known what wires are serving or whether needed or not.
Thanks for taking the time to look.
what is this on the mk1 loom? basically leave the lighting part alone, no mods needed there.
on the engien loom you remove everything except the wiper motor and dash sensors. keep the other wires in place for now as you may be able to use some of the feeds. for example you'll have some ignition lives you might make use of, there is a wire to d/13 which you shoudl splice the the 20v fuel pump relay earth pin then you can run your fuel pump safely.
read this thread all the way thru till the end, ive covered ce1 -> 20v wiring in detail:
http://www.clubgti.com/showthread.php?205887
