Help i've lost the Horn!
(In Topic #85473)
A little help if you please - My horn has stopped working!
I've had a quick check of all the connections at either end and they all seem fine, fuse is ok too. Removed the steering wheel what I could find and there appears to be a brass electrical connector which should make contact with the rear of the wheel.
However the one on my car appears to have worn away, or atleast it has a large hole worn in it!!! Could this be the reason for my problems? If so any ideas if they are still availble????
All help appreciated as always!!
Jamie
http://i169.photobucket.com/albums/u210/TheCampaigner/100_1444.jpg
Vagcat doesn't show the plate in the diagrams so no idea what the part no is.
Try crazyquiff or scouse or your local breakers.
Mk1 GTi White Cab '86
Mk4 TDi
Mk4 TDi
May try and get some pics up so you can see how it looks and tell me if it looks right??
Mk4 TDi
Mk4 TDi
